Can anyone help to find best vst for voice?
Hi All
I am interested in downloading VST Plugin for voice. Can anyone help to find best vst for voice? I need best so that the sound could be recorded in good quality like studio.
Hi All
I suggest this for you:Â Synth
This has 2 Oscillators to provide excellent signal, FM modulation that will strengthen up your signals, ring modulation which will help gain good frequency by mixing two frequencies, sync will allow for any data transfer, along with all the best modulations, this also has modulation envelopes to bind (low, upper, sidebands) together.
There are 4 types of filters to prevent frequency from being distorted. 2 inbuilt LFOs below 20 Hz will create a rhythmic pulse. Inbuilt Arpeggiator will be of great use to you if you are interested in editing existing notes, or you may take benefits of already present notes. Portamento will be useful in changing notes. It possesses 16 notes polyphony with 128 presets. With all these amazing technologies, the best factor is this uses SSE instructions for light CPU load.
