April Rosas
30 points
Posted on - 01/22/2013
I have not much more experience how to convert files CSV to PRN. I have 24 amount of CSV file to convert. As I do not know the system so I can not convert this CSV files to PRN. Anybody here to help me. Let me know the system of convert files CSV to PRN.
Thanks
Can anyone help me to convert files csv to prn?
Hello
I found application which will do work for you. It can convert CSV (comma separated value) into any tex file including prn.
Just download it from this site: http://www.fileguru.com/CSV-To-Shapefile-Converter/info and start using it. It is free application but it's very capable of doing it's job. You'll have to download around 23 MB of data.
I hope I helped, cheers.
Hi there: A quick way to convert the file is to open the .CSV in excel. Once that’s done, you may try save the same file with file type .prn. If that’s not what you need, there are excel macros available that can do the conversion. Here is one macro: www.excelbanter.com/showthread.php?t=374300. Hope this solves your issue.
Hi Rosas,
To do so, I think it would be better if you open few files together and then hit F12 and a new box will appear; now near the bottom you will see “save as type”, from the dropdown menu select .pnr or select “Formatted Text (Space delimiter)”. Now just hit save button.
Also you can try the macro in this below link. It works fine in the mentioned versions at the bottom of the page.
https://support.microsoft.com/en-us/help/249885/formatted-text–prn-is-limited-to-240-characters-per-line-in-excel
Best regards,
Riley Weaver.
