Can anyone help me to install disk doctors undelete?
I am trying to activate disk doctors undelete but when I put the serial number and click the activation button it says that activation failed.
Am I doing something wrong?
I checked the serial number twice.
Has anyone any experience in disk doctors undelete?
Best Answer by Willet Engelin
Answered By 0 points N/A #150038
Hello Robert,
I think you are troubleshooting with disk doctors undelete activation process.
Here I am going to give you some effective tips.
Hope after applying these you can successfully active your software.
  • First it should inform you that after completing purchase you will be sent a message which is contains hyperlink for download the software with associated serial key.
  • Before download first you have to scan every file and if you using demo you have to remove it to the other location and need to uninstall it.
  • Install data to a definite drive. Partition will make your software to create troubleshooting during installing or after installation
  • In case of file loosing troubleshooting you need to install it other drive to eradicate the problem. And for these you will need to make another drive as master drive through again operating system installation.
  • Don’t try to active the software from the Pendrive or other similar like that and for this activation will not be possible.
  • Using serial key given with confirmation message is the way to automatic installation process
  • If it fails because of internet connection problem and for using firewall you need to do it manual and for manual installing process you need site key for activation.
  • When you try to do it manually using the below manual process procedure, after having your site code they will sent you site key after checking your validity.
For automatic activation you need to look up it.
For Manual activation you should follow this direction
Hope after following these you will be able to successfully eradicate the problem.
Thank you
Answered By 0 points N/A #150039
Hello Robert Martin:
Before downloading and installing the full version of the software, Please ensure that you have
  • All your save scan output file and related files created using the demo version in place
  • you have uninstalled the demo version to avoid any conflict or confusion.
 Once you are sure of everything, start download and install the full version of the software.
Note:
             Never install Disk Doctors Undelete on the drive from which you want to recover data.
Answered By 590495 points N/A #310335
If activating an application fails but you know you entered the serial number correctly, make sure your computer is connected to the internet. When activating an application, sometimes there are programs that require internet connection and there are also ones that can be activated offline. If your computer is disconnected from the internet and you cannot activate your program, try connecting to the internet and try activating again.
See if this works. Also, when entering the serial number for activation, make sure you enter the code exactly as it appears. If the character or letter is in small case, enter it in small case. If it is a big letter, type it as big letter. If you can copy and paste the code, do it to avoid problems when entering the code.
Another reason why activation fails is if you are using a serial number you found on the internet. Normally, these codes are blocked and can no longer be used. If you want to use the program, buy a license to receive a valid serial number that will work only for you.
