Hey, I cannot run my GTA 5 smoothly on my Windows 10 PC, as the game crashes suddenly. There are no specific instances for that. My virus scan shows no infection. Can anyone help me to solve the 0xc0000005 GTA 5 exception code?
Can Anyone Help Me To Solve The 0xc0000005 GTA 5 Exception Code?
I have faced a similar exception code. I will help you with the methods that are helpful to solve the 0xc0000005 GTA 5 exception code.
Method 1
a. Go to C:\Users\YOUR-USERNAME\Documents\Rockstar Games\GTA V\Profiles\ACCOUNT-CODE.
b. Find two files – cfg.dat and pc_settings.bin.
c. Take a backup of the files.
d. Delete the files.
e. Restart your game.
f. You have to do some settings again, but the problem will disappear.
Method 2
a. Press Windows + R on your keyboard.
b. Type services.msc and press enter.
c. Double-click on Rockstar Games Library Service.
d. Make the Startup type as Automatic.
e. Restart your PC.
f. Your problem should disappear.
Method 3
a. Start your game.
b. In the windows search box, search resource monitor, and open it.
c. Go to the Memory tab.
d. Right-click on GTALauncher.exe, and end process.
e. Play your game.
