Can Anyone Help Me With This 0x8ccc0003 SMTP Error?
Hey, Everyone! I was using my mail app on my PC when suddenly I was greeted by this lovely 0x8ccc0003 SMTP error. Can you please help me removing of this 0x8ccc0003 SMTP error?
A) To fix the 0x8ccc0003 SMTP error, you will need to follow these steps:-
1. First, you will need to Re-configure your account in Windows Live Mail by following the procedure that is present inside Windows Live Mail by the name of How to configure a Windows Live Hotmail account. You will need to remove the account before re-configuring it.
2. Now, access the account using POP3: If you are using dial-up, try gaining access to your account using POP3.
B) To fix the 0x8ccc0003 SMTP error, you will need to check that the mail server that you are sending or receiving data from might is available or not.
