Hello people. I would like to create a compressed or customizable self-extracting exe img boot file of my HDD. Can someone suggest an img boot file creator that is easy to use? I'm on Windows Vista 64 bit. Any suggestions would be highly appreciated. Thank you.
Can anyone suggest an Img boot file creator?
Hello there William,
Creating image boot file like ISO is a nice thing if you want to access your drives easily. Though in ISO you can make your own virtual drive. For windows vista, there is a bootable image creator available. Windows Bootable Image Creator is an easy to use application developed by windows to create a bootable ISO image file. Here is the link to download it : http://www.softpedia.com/get/System/Boot-Manager-Disk/Windows-Bootable-Image-Creator.shtml
Hope it helps you
Regards Ronald
