Can anyone suggest me a good firewall
Hi guys , I need your help to find a good firewall to my laptop , Right now I have kaspersky 2009 Internet Security , but I need a good firewall , which need to show what are the programs use internet most
If you have kaspersky 2009 internet security I suggest that you upgrade to kaspersky 2012 internet security and please follow the tips I would give you.
1. Please update your antivirus and have a full system scan, this is just a weekly maintenance on your computer you can do it once a week. ( You must have a Good and trusted antivirus I recommend using kaspersky and Norton)
2. Have a registry cleaner and fixer ( I will give you a link on the program that I am using http://www.piriform.com/ccleaner/download) Please download and install the program and Run it. Click on the registry and scan for issues and it will fix it.
Hello Kathleen.
The built in firewall of Windows is already capable of protecting your computer from incoming threats. However, if you prefer stronger firewall protection, Comodo Firewall is no doubt the best software firewall that you can get. It monitors all incoming as well as outgoing connections. The default Windows firewall by comparison only tracks incoming connections. This two-way monitoring of Comodo ensures that malware attacks will never originate from your computer. It also has the excellent Defense+ feature that monitors the behavior of unknown applications. With Comodo firewall and Defense+, you can be sure your antivirus gets support in protecting your machine.
Best of all, Comodo Firewall is free.
Hope this helps!
For a workstation like a laptop or a desktop computer, Kaspersky is fine either antivirus or internet security. It should give you better protection for your system and personal information. Kaspersky Internet Security offers both antivirus and personal firewall. It can protect your computer for viruses with its antivirus and unauthorized access with its personal firewall.
If you are not satisfied with your existing Kaspersky Internet Security, try other security products like ESET and Norton. To try different ESET security products, go to ESET Offline Installers. The latest version at the moment supports Windows 7, Windows 8.x, and Windows 10. The latest version at the moment is ESET 12.0.31.0 (ESET Smart Security Premium 12.0.31.0, ESET Internet Security 12.0.31.0, and ESET NOD32 Antivirus 12.0.31.0).
Support for Windows XP and Windows Vista is until ESET 8 only. If you want to try Norton, go to Norton Security Deluxe. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Before, there were Norton Antivirus and Norton Internet Security. These Norton security products are now gone.
Symantec decided to merge these two products into one resulting to the creation of Norton Security Deluxe.
Notifications
