Can Anyone Tell Me A Way For Downloading A Serious Error Has Occurred Ps3?
I was recently playing on my PS3 when I realized that I was suddenly hit with an error saying a serious error has occurred ps3. Can somebody solve this problem?
To fix this “a serious error has occurred ps3” error, you will need to follow these steps:-
1. Keep pressing down the power button and when it comes on.
2. Keep on pressing and holding it unless it switches off, and if red again, then let go.
3. After that, keep on pressing it again, and you will hear a beep.
4. Keep pressing and holding it, and then you will hear a second beep. After that, let go plug your controller in with the USB cable and hit on the PS button.
5. You will see the options. Now, select the restore file system option; and ps3 will restart after completing that option.
6. Now, go back to that menu again by following these first three steps and select the rebuild database option. Your PS3 will restart once again after completion, and the error will be gone.
