Dear Experts,
While surfing the websites I came to know about software known as Vision Info which is able to manage Plumbing and Electrical bids. I am using Mac OS Lion 7.3. Is this software available for Mac?
Can anyone tell me about Vision Info software ?
Vision info Software is the Professional Contractor Software for Electrical and Plumbing.
They don't have this software for MAC OS version.
Regards.
Noel Sammy.
Hi Alisa,
Vision Info is a software usually used by electrical and plumbing contractors to manage their projects. It maintains a database of wires, fittings, straps and all that have something to do with electrical projects. The software is not only limited to contractors but also to homeowners who starts their own home projects. Rather than maintaining a spreadsheet this software will help you with much more that a spreadsheet can do.
You can manually input scheduling and pricing of materials. Should you be doing window shopping for materials or for contractors biddings then it will also allow the user. It is not limited to materials prices but helps users with their projects expenses and profits which calculate everything for you. Everything to do about installation of electrical wirings and plumbing it makes sure it's part of your project cost. Sadly, it is only compatible with Windows XP, Windows Vista and Windows 7.
Hope it helps.
