anewman15
50 points
Posted on - 11/15/2012
I have a huge DVD collection and I want to create a backup for them. I need to remove the copyright details without losing the originality and quality of my videos. Can you please tell me how to shrink a movie for Mac according to my preferences above?
Thanks
Can anyone tell me how to shrink a movie for Mac?
Yes dear, you can shrink your DVD movie with DVD Shrink Mac. It’s really good, easy and powerful. It provides multifunction including compressing, burning and it keeps the original quality. It will fulfill your preferences and remove the copyright details without losing the originality and quality of your videos automatically. Hope a good luck.
I have found the perfect software as per your needs. You can download the software, MacTheRipper, from the link given below.
It allows you to rip DVD's, shrink their size while maintaining the original quality. You can even remove the copyright material. I guess this is the perfect software for you.
Link:Â https://www.macxdvd.com/mac-dvd-video-converter-how-to/mac-the-ripper.htm
Hope this helps!
Drianna allen
