Can Anyone Tell Me What 0x80072f76 0x20016 Error Is?
Hello, Everyone! I was hit by this 0x80072f76 0x20016 error when I was I started my computer. Please help me to fix it?
A) The 0x80072f76 0x20016 error means that there is some error like registry issues, compatibility issues, the system is rejecting update, and so on. To fix 0x80072f76 0x20016 error, you need to run the troubleshooter on the windows update by following these steps: –
1. Start> Settings> search for the Troubleshoot settings in the search area box given above in the window.
2. Click on it, and then, go to troubleshoot and find the windows update option and run the troubleshooter on it by pressing on it.
It might fix it.
B) To fix 0x80072f76 0x20016 errors, you need to run its previous version of windows inside the compatibility option by right-clicking on it and choosing that option.
