Can Anyone Tell Me What 0x87e10bd0 Windows Store Error Is?
Hi, everyone! I was using my computer when I received this 0x87e10bd0 windows store error. Can anyone fix it?
A) To fix these 0x87e10bd0 windows store error, you will need to follow these steps:-
1. Press the Windows menu key and the R key altogether to open the Run Dialog-box window.
2. Write down %windir% inside it and hit the Enter key. You will be inside the Windows folder.
3. Find and Locate the AUInstallAgent folder. If it is not available or missing in the Windows folder, you will need to right-click and then choose to create a new folder option from the New menu.
4. Change the folder as AUInstallAgent.
5. Restart the computer.
B) To fix this 0x87e10bd0 windows store error, you will need to follow these steps:-
1) Click and hit the Windows key and the R key altogether to open the Run Dialog-box window.
b. Write down wsreset.exe inside it and then hit the Enter key. It will reset the windows store.
