Can Anyone Tell Me, What Is 0x0116 Mean?
Hello, Everyone! I was hit by this 0x0116 error when I was I started my computer. Please help me to fix it?
Answered By 0 points N/A #340729
A) 0x0116 error indicates that an attempt to reset the display driver and recover from a timeout failed. It is caused due to faulty hardware or software corruption. To fix it, you need to check for windows update in the control panel and update your system to fix this problem.
B) To fix this 0x0116 error, you need to go to the device manager and check for updates, and if there are any updates for drivers, update them and restart your system to fix this error.
