Can Anyone Tell Me What The 3dx9_43 Dll Error Is?
Hey, I got this error telling me that the 3dx9_43 dll file is not found on PC to run the program. Please help me correct this issue on my PC?
A) To fix this 3dx9_43 dll error, you have to follow these steps:-
1. Open up any browser and go to any search engine of your choice like Google and then search for 3dx9_43 dll.
2. Then, you will have to go to this link
3. Now click on the “download it” button and download it according to your software system version. It will open a new page, and your download will start automatically within a few seconds.
B) To fix this 3dx9_43 dll error, you have to follow these steps:-
1. Inside the start, menu search, type cmd, and then run it as admin.
2. Inside the cmd type command sfc /scannow.
This command will scan your PC for corrupted or damaged files inside your system and then replace it with a fixed one. In some cases, it solves the issue.
Notifications
