Every time I run full scan AVG stops Google Chrome! This means Google Chrome just stop working which means I can't run the scan and use Chrome at the same time. But when I stop or pause the scan Chrome works again. Should I set anything anywhere or it is just the way it is for the two programs? Please help.
Thank you.
Can AVG stops Google Chrome?
It is not the fault of AVG. It happens because of malwares or spywares infection. The best solution may be using any good spyware remover. Download any software and scan your pc with that for searching and killing those spywares. Microsoft security essential or windows defender may fruitful for this.
You may reinstall the Chrome also.
Yes, because the AVG will blocked the internet that’s why the Google chrome will not run when AVG(Anti Virus Guard) is functioning or scanning ,we cannot run the AVG and open the Google Chrome at the same time .
