Hi guys. I need the opinions of Baan Query Tool users.Â
I plan on getting Baan Query Tool 3.0.Â
Will it work directly with BShell and do I still have to configure ODBC?
I really need your reviews and opinions guys.Â
Thanks in advance.
Can Baan Query Tool work with BShell?
There is a new way to create reports on your Baan or Baan Query Tool. This Baan session is a Query that builds with graphic interference. Your Queries reports can be exported to Excel. It is install very quickly it Load few Baan and all Baan users will have access to Baan Query Tool. It is very easy to configure.
Use Baan Data Dictionary Browse Baan tables and fields and create a query – using the Baan data you don’t need to remember the field and the name. Baan Query Tool is fully integrated. Reports run as native Baan reports.
Can work with Baan special fields. For example, enumerated fields, arrays & text.
