Can Battsaver really double your battery life
I suppose this is wishful thanking but I'm hoping it is real. There is a product called Battsaver and it is suppose to double your battery life. Is any of this true.
Hi Carey,
It is true that BattSaver  increases battery life. It's Supremacy comes in to the fact that the package automatically switches of anything that is not being used. Normally, these usually drains battery power  hence reducing its life.
Also, it has plans of how the device should save power. With its feature of monitoring to check battery state in real time and a refresh feature allow  battery power to be saved. All these increase battery life.
Hope I was able to help.
BattSaver is a battery-saving app for jailbroken devices. It is one of the most popular and regularly downloaded tweaks and claims to double your iPhone’s battery life. It has now been updated for iOS 9. The app introduces a number of enhancements which brings in extra functionality to those interacting with the tweak.
It also offers stability enhancements and bug fixes that should make the app experience a lot smoother on all iOS versions it supports. The Low Power Mode support for the new iOS 9, one of Apple’s new attempts to save battery power by disabling less important activity on the device when the battery reaches a particular percentage, has been integrated into BattSaver.
The latest version, BattSaver 2.1.0, introduces a new feature that permits explicit power management when the device is connected to cellular data either 3G or 4G. If your iPhone has been jailbroken and you are experiencing battery problems and want to have a better handle on how to manage and preserve battery life, BattSaver 2.1.0 would be the perfect solution.
This is not a free tweak though. It costs $3.99. To buy it, go to How To Buy Paid Cydia Apps. Take note: the BattSaver app requires a jailbroken iOS device. If your device is not jailbroken, go to iOS 9 Jailbreak to learn how.
