Can chip firmware img editor work on any image type?
I want to use chip firmware img editor to edit every picture I get. I'm wondering if this image editor supports all file formats of image, from jpg to gif or bmp. Can chip firmware img editor work on any image file format?
Best Answer by Sharath Reddy
Answered By 0 points N/A #133839
Hello Clara,
Yes, you can edit every picture you get on chip firmware image editor. It could edit all formats of image.
Answered By 590495 points N/A #133840
I think you are referring to the general information regarding chip img viewer or editor not to a particular application only since there are lots of different chip img editor available in the web. I’ll list some of those I found below together with a brief information.
  • Sharp IMG Viewer — this is a resource explorer which requires the installation of Microsoft .NET Framework 3.5 Service Pack 1 created for Microsoft .NET Framework 2.0 and later versions that allows a user to save images in different formats, open and extract images from different sources, execute processes on chosen images, and view image properties as well as its metadata. This costs $45.
  • Img Tag Updater — this is a freeware tool that automatically updates and adjusts the width and height attributes of IMG tags in HTML documents based on the source image’s original width and height or its size or dimension.
  • DESK-IMG — this is also a freeware tool that allows you to automatically zoom images to fit the screen’s width and height and is also able to recall the last choice you made.
You can also check Podnova – Windows Library | Chip firmware img editor in Title/Summary for more versions.
