Can DupliChecker show source websites?
I’m planning to use DupliChecker, the free plagiarism detector online.
Do I have to sign up or register to use the website?
Would it show source websites from where an article was copied?
Would it also have a compare option to show the similarities of the 2 articles?
Best Answer by Sharath Reddy
Answered By 0 points N/A #144170
Hey there!
DupliChecker is a free online software for plagiarism. You can use it without registering with limited but if you plan to use it like many times then I'd like suggest for you to register, it's not time consuming anyway.
Yes, it will definitely show the source websites the article you copied from, and it does compare some similarities if even it's only a sentence/paragraph.
Answered By 590495 points N/A #144172
No, you don’t necessarily need to register if you don’t have plans of using it frequently like everyday. You can use it even without registering for an account but as a guest user or unregistered user you are only limited to about 3 searches per day.
This is really one great tool to check your site’s contents for plagiarism because I’ve already used it and I’ve also tried using it as an unregistered user. As a guest, I successfully made at least 3 searches which displayed good results.
After that I was surprised that I can no longer make further searches. But then again it’s my first time to use it so who can blame me. I forgot to look on the FAQs. Dupli Checker – Free Online Software For Plagiarism Detection is really one great online tool for learning plagiarism contents. Watch “Free plagiarism detector online, DupliChecker | video tutorial by TechyV” to better understand it.
[video:http://youtu.be/Gx_LmplEA30]
