Hello expert, My friend is using the Nokia E63 mobile. He need to play some flv files on it. But when playing those files only audio is playing. Can E63 play flv files without installing the flv player? Please can you suggest me an easy way to play flv files on his mobile?
The Nokia E63 does not have native FLV support. You need to convert the FLV files to 3GP or MP4 format in your PC first, then load it up in the E63 for playback.
I would recommend the Pazera Video Converters Suite for converting video files. Its standalone, lightweight and completely free!
The Nokia E63 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and UMTS technologies. It was announced to the public on November 2008 and released on December 2008 measuring 113 x 59 x 13 millimeters and weighing 126 grams. It uses mini-SIM card and has QWERTY keyboard. It has TFT display with 16M colors at 320 x 240 pixels screen resolution.
Nokia E63
It ships with Symbian OS 9.2 with Series 60 v3.1 UI powered by 369 MHz ARM 11 processor. It supports microSD expandable up to 16 GB. It has 120 MB internal storage. The primary camera supports 2 megapixels featuring LED flash. It can record video in 320p at 15 fps. There is no secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g, Bluetooth 2.0 with A2DP support, FM radio, and microUSB 2.0. There is no GPS and built-in sensors. The pre-installed web browser supports WAP 2.0/xHTML and HTML. It runs on removable BP-4L Li-Po 1500 mAh battery with standby time up to 432 hours on 2G and 480 hours on 3G.
Talk time is up to 11 hours on 2G and 4 hours 40 minutes on 3G. It is available in Ultramarine Blue, Ruby Red, and Black colors. If you tried playing FLV files and you only get audio, that’s because the FLV file format is not supported. It only supports the following video formats: WMV, RV, MP4, and 3GP.
1....
