CAn Excel employee leave calendar be color-coded?
I'm using an existing template from excel to create a leave calendar which has a column for each day and a row for each member.  Can excel employee leave calendar be color-coded so it will be visually easy?
Answered By 0 points N/A #144807
Dear Josh Pikee,
You didn't mention which version of Excel you use. There are many versions. If you don't find any template, you’ll find in latest it version. I am giving the steps of the Office 2007 version how to use color in rows and columns.
1. Select a row and go to Home and then click Fill > Select color > Fill color.
2. Select a column and go to Home and then click Fill > Select color > fill color.
Hopefully, that will do and it will be helpful for you. It's so easy. I hope you can do that.
