I recently launched my Avast antivirus version 7.0 1474. It detected a Win32 MBRoot-J Trojan virus which I deleted. Some of my important files also got deleted during the process. I need to recover lost and deleted files. Would File Recovery Pro do the trick?
Can file recovery pro get the job done?
Hello Dear,
Yes, Data recovery pro can do this. This software can recover a wide variety of files. It can recover missing/deleted files from peripheral storage devices. It can also recover data from formatted and partitioned drives. It is very sophisticated software. It has a completely update filter which allows you to search your lost text by keyword or phrase. Hope you will get rid of this problem.
Wish you the best of luck.
