Can Folder Guard hide encrypted files?
Where can I download Folder Guard Pro freeware? What kind of encryption does it use for files and folders? Can it also hide the encrypted files from other users? Will it work on external HDD’s?
Just as I thought, when you said “Folder Guard Pro” and a “freeware”, I don’t think you will find any freeware programs with “Pro” in it. A freeware application is a program that any users can download and install for free and without limitations like in a trial version or demo program. It is a free fully functional application that can be used and distributed by any body. When an application has a “pro” in it, it means it is a commercial product and sold for profit. So if it is Folder Guard Pro it is not a freeware but a shareware maybe.
Folder Guard is a strong security program that a user can use to control access to the files, folders, and other Windows resources. With this tool in your computer, you can actually lock any files and folders by means of a password. You can password-protect unlimited number of folders with their individual password or unlock them all at once by means of a Master Password. It costs $39.95 for a personal license and $79.95 if you’ll be using it in your business and supports Windows XP, Windows Vista, Windows 7, and Windows 8. It has a free 30-day trial period and can be downloaded from WinAbility® Software | Folder Guard for Windows 8, 7, Vista, XP.
You may also watch the video “Encrypt / password protect files and folders with Folder Guard | video tutorial by TechyV”.
Hello friends! I am really amazed about how secured my personal data are! That is just for you guys. I was also searching to get the best encryption software and found the Folder Guard Pro. However, I have got trouble finding the downloading page of Folder Guard Pro. Here I have succeeded to get the most reliable source of Folder Guard Pro. I don’t know how it helps protect my data. Its answer is also here. I am really happy and the amount is so large that cannot be told in words. You are enriching my knowledge. Thanks guys for helping me greatly and I really appreciated also the video that you posted.
