Can ftp connection to Google storage php corrupted?
I have tried using FTP connection to Google storage PHP.
I used it to save my PowerPoint presentation so that I can be able to transfer it to another computer without using any USB cables.
The problem with it when I downloaded it is that the file was corrupted.
It was working though when I opened it from the computer I used to send it.
Could there be a possibility that there was something wrong with the way I transferred it to the Google storage?
Best Answer by carpenter harrer
Answered By 0 points N/A #153446
Hello Asteneves,
Hope that my message finds you well.
First of all make sure that the problem is not with the Microsoft PowerPoint on the received PC.
If that's not the problem Please follow the below link it’s a guide and index for anything you want to do with
Google storage:
https://support.google.com/drive/
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
Answered By 5 points N/A #153447
Hi Asteneves,
The problem with your file might be that it never finished downloading completely. Have you tried re-downloading it several times? Again, your computer might be the one with a problem such as it may be infected by a virus.
Another point is that maybe the computer with the original file has viruses and they corrupted your file. You may have uploaded the corrupt file to the web storage. Kindly find a good antivirus such as AVG and scan first the files.
If however you are unable to find a solution, please ask Google technicians to help you out.
