I have this Desktop it’s an Hp pavilion HPE H8t series. It has a 1 GB DDR Ram with a Radeon HD 6670 Graphics Card. All I wanted to know is whether the Graphic Card could have a Digital user interface (DVI) so that I could use it on my Monitor, Because my Monitor Has a DVI –D connection  and I want to have a digital kind of connection with it, what do I need to use so that I can link that up ?
Can a Graphic Card have a Digital user interface (DVI)?
There are four types of connections you can make with Radeon HD 6670 Graphics Card. It has available display outputs that supports,
VGA
DisplayPort 1.2
HDMI 1.4
Dual-link DVI with HDCP
Radeon HD 6670 Graphics Card has a Digital User Interface (DVI) port. Â Therefore if your monitor has a DVI connector you can connect your desktop computer to the monitor using a DVI connection. Â In order to do that you should have a DVI cable. There are three types of DVI connections; DVI-Digital, DVI-Analog, and DVI-Integrated. As your monitor has a DVI-D connection, you should use a DVI-D cable which can be used for direct digital connection between video card and monitor.Â
