Can gui designed for access 2010 function in access 2007?
My MS Access is still an access 2007. I want to use the new gui. Can I use gui designed for access 2010 in my access 2007?
No, I believe that it's not possible to just transfer or export the interface of applications like these and this is also true for almost any type of applications out there. If you really want to work with MS Access 2010 gui then you will just have to install that version of Access on your computer.
Hello
I'm afraid not since you are trying to use something new in something old. You can do oposit, you can make gui in 2007 and import it in 2010. Like any other application, for example Word, can't import something what is made after that application. So for example Word 2003 can't open docx files since they are made for 2007 and later. Cheers.
