Can HTC pcsync osx Mountain Lion in Mac? I have an HTC One V with Android 4.1 (Jelly Bean), Qualcomm MSM8255 Snapdragon chipset and MacBook Pro with upgraded OSx Mountain Lion. Would an android platform be compatible with OSx? Need some feedback on this. Thanks people.
Can Htc pcsync osx Mountain Lion?
Good day Marilyn
Yes, it is possible. First of all you need to download the Mac version of the PC sync software and install it, https://www.iskysoft.com/phone-transfer/sync-htc-to-mac.html
Then on your phone you need to configure settings so that the Mac and the phone can sync.
Go to setting then applications.
Then click development, then USB debugging.
You will have to tick, USB debugging , stay awake, allow mock locations.
Scroll down the top window down to get to usb connected.
Click on USB connected, and click on mount.
Now on the Mac your connection type will be mount as disk drive.
Click on done.
Now you can transfer files between the 2 devices.
