Angela King
10 points
Posted on - 02/06/2015
How to adjust the color of a printer externally by hand. I need the printer to match the monitor, it doesn't make difference whether both of them are perfect.
Is there a way that you can print a test page, and then on a monitor adjust the color until it matches the printed version. After that when you print, it would do the opposite operation, so that it matches the monitor?
Can I adjust printer color by hand?
Hello Angela!
I am sorry to disappoint you that we cannot adjust manually the inks color set-up. Printers nowadays comes with software where you can control the color for any print outs. Do not follow any instructions over the internet telling you simple hacks that might cause damage not only to printer’s cartridge but also to printer itself. On the time you purchased you printer, utility disk included. Please locate or if you misplaced the driver we can download software where we can change color settings before printing.
