Can I be safe from FaceBook Viruses and Taggers?
Hello friends, I am a regular user of FaceBook and I am very much annoyed of different attacks on my wall post and tagging these days. I just want to get rid of this problem.
Please help.
Mita
Please help.
Mita
Hi Mita,
It’s not a big problem because its solution is in your hand.
You should change your privacy settings according to your desires. In this regard you must follow these steps.
First of all login to your FaceBook account then go to privacy setting (this option is present in the dropdown list at upper right corner, above the logout option)
Here a new page will be open select custom settings.
How You Connect > hit Edit setting > make settings according to your choice.
Timeline and Tagging > Hit edit setting
Who can post on your timeline? Click on dropdown option and select No one
Review tags friends add to your own posts on FaceBook select off
Who sees tag suggestions when photos that look like you are uploaded? Select No one
After this press Done button
Now open account setting > notifications >Uncheck Email frequency (at upper right side of page)
FaceBook > edit > Uncheck all tag options> save
Photos > edit > Uncheck all tag options> save
Do same steps with the remaining options. You will get rid of your problem related to FaceBook
Regards
Sylph
Notifications
