Can I change to windows classic style 2007 without disruption?
I have a Windows XP installed in my PC but I want to change to a windows classic style 2007. Can I change to windows classic style 2007 without changing any file, program or icons on my desktop?
Best Answer by Michelle Karla
Answered By 15 points N/A #167822
Is it that you want to change your operating system toa windows classic style 2007? If yes then the answer to your question would be. Your file, program wouldn’t change but the desktop icons are going to be changed and you will have to redo the icon change after the installation of the new OS.
Hope you found this helpful.
Answered By 0 points N/A #167823
Hello Kurtt Stewart,
If I understand correctly, you want to change your Windows Xp theme to Windows Classic. Please follow the instructions:
– Right click on an empty area on the desktop, and then click Properties.
– On the Themes tab, click Windows Classic in the Themes box.
– Click OK.
I hope this helped you.
