Finlay
50 points
Posted on - 01/28/2013
Can I send and receive email in Mapi server Solaris environment or is there a way to configure this?
Will Remedy Email engine work on this?
Will MAPI protocol be able to communicate with Exchange if I use this engine?
Can I check email in Mapi server solaris environment?
Hello Finlay
You don’t need to worry about Remedy Email Engine about MAPI server.
Many small company owners or personal users.
Here are some configurations you may need.
Assorted tools, etc, also running on Windows
BMC Remedy AR Server on Windows
Microsoft SQL Server on Windows
You can get more details about the exchange in here.
Regards
Remedy will work in Solaris environment, however it is no longer listed as a recommended solution on the bmc.com. Recommended solutions are either Windows or Red Hat Linux.
Solaris provides a program for sending and receiving electronic mail, called "mailx" which is not window based and hence can be run on any terminal.
