I have a couple of MSG files that I have received, but it looks like Mozilla Firefox can not open them.
Can you please help me configure Firefox to open MSG files because I don't know exactly what do I need.
I have searched for plugins or software's online, but found nothing.
Thank you Techyv.
Can I configure Firefox to open msg files from Outlook
In FireFox, click on FireFox button (in orange), choose Options and then click on Applications tab.
In this windows you will see tow columns named Content Type and Action.
In Content Type column choose you MSG file and in the Action column choose Outlook from the drop down menu. If there is not Outlook there then choose Use other…, from the pop up window choose Outlook from the application list. Press OK on every window.
