GalinaF
Posted on - 11/20/2012
Hi everyone,
I am wondering is it possible to convert .doc files to .xls files on mac os without preliminary converting .doc to PDF and then PDF to .xls as I am having to do on windows? Or does it sound too fantastic even for mac?
Thanks
Can I convert .doc files to .xls files on Mac?
Hello Galina,
Yes its possible to convert your .doc files to .xls files on your current Mac os you are right it's sound fantastic for those who didn’t try this one on there Mac its very simple just open Google of the largest search engine in search write .doc to .xls converter in search you can see many site some of them allows you to convert directly no need to install if you want to use it on your machine then download. It directly converts your .doc to .xls these all things are on single click if you got any issue feel free to question I will help you
