Can I convert Linux image fax to TIF?
I received and opened an attachment. I can ‘open with’ a selection of programmes but I want to save the attached file as a TIF. Can I convert Linux image fax to TIF?
Yes, you can do this by using the most popular image editing software Adobe Photoshop. Follow the steps below:
1.  Run Adobe photoshop.
2.  Open the Raw formatted image with photoshop.
3.  Edit the image if you want.
4.  Now go to File > SaveAs > Choose TIF format from the drop-down format menu.
5.  Click to save button to finish.
Thank you.
Hi Davionevan,
I have reviewed your issue; you are looking to convert Linux image fax to TIF
Yes, you can convert Linux image fax to TIF, Please follow these steps to convert Linux image fax to TIF:
1.  Run Paint (Which is inbuilt with Windows and Linux os).
2.  Open the image (you need to convert).
3.  Now go to File > Save As > Choose TIF format from the drop-down format menu.
4.  Click to save button to finish.
I wish this solution may be helpful. Thanks!
Best,              Â
Fenster Maxine
