Jose V Lau
20 points
Posted on - 08/10/2013
I have about 14 .xls files made in Microsoft Excel and I want to convert them to .exe.
I have searched online but I couldn't find a software to do this.
I need a software that will convert XLS to EXE online and can help me to secure the files, and protect them.
Please after you recommend me a software, write me some features.
It must be able to protect my files from being copied.
Thank you in advance TechyV Support.
Can I convert XLS to EXE online free
Hi there Jose V Lau,
There are several converters available that can convert .xls files into executable files and I would like to recommend you a few of them.
XCell Compiler is a simple .xls to .exe converter that will convert your files into executables in just a few moments.
It is not free, but offers a free trial you can try and use. You can find it at the link.
Another converter I'd like to recommend is XL To EXE Converter. It is a free utility that will convert any of Microsoft Excel files to EXE files.
You can find it here .
Best regards,
Drake Vivian
Hi Jose
I recommend you to use VaySoft Excel to Exe Converter. It converts XLS, XLM, XLSM, XLSX to EXE.
It not just convert file you can set the limit to view your file and if the end user try to open the VBA code it automatically close
And also you can use copyscape, it defends your files for being copied by others.
If you need to convert an Office Excel file (.xls) to EXE format, you can use an application called DoneEx XCell Compiler. It is known also as XLS to EXE converter and it offers very easy and hassle free XLS to EXE conversion. You can convert different Excel files like XLS, XLSX, and XLSM into a normal EXE application with securely hidden formulas in binary format.
The application guarantees the strongest copy protection for Microsoft Office Excel workbooks. DoneEx XCell Compiler supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It supports Office Excel 2003 32-bit only, 2007 32-bit only, 2010, 2013, and 2016 both 32-bit and 64-bit.
The application compiles your workbook into an executable application where all formulas are securely converted into binary format which cannot be restored back into the original Excel formulas.
