Can I Disable ipv6 Group Policy In Windows?
I am using Windows 97. I need to disable IPv6 group policy is there any way to do the same. Please provide with steps will be more useful
You may follow the steps to disable ipv6 group policy
Step 1: Download the IPv6ConfigirationFile from the given link
http://www2.expta.com/IPv6Configuration.zip
Step 2: Extract the file and copy the given files into the C:/Windows or %systemroot% folder. You may have to provide administration permissions.
Step 3: Open Run dialog by pressing Ctrl+R and type “gpmc.msc” to open group management policy console.
Step 4: Double-click Default Domain Policy and click Edit.
Step 5: Select Computer Configuration–>Policies–>Administrative Templates–>Network–>IPv6 Configuration.
Step 6: In the settings tab, Select Disabled and click on the OK button.
The group policy will be changed.
