Can I do java apps downloads for ipods
I am curious about downloading java apps for ipods. Is it possible? Provide instructions about java apps downloads for ipods.
I’m not sure if you can install Java applications on an iPod device since most of the information I found on the web says that “iPod touch does not support Java”; “Apple iPhone will not support Java applications of any kind”; “The Apple iPod does NOT support Java applications”.
I haven’t used any Smartphones yet that’s why it’s hard to justify if this is true or not. There is also one post that says to be able to install Java applications on Smartphones you have to jailbreak the device. To learn more about it, please visit How To Install, Compile, Run Java On iPhone.
