Can I download Nokia C7 original themes having blue color?
Is there any website available that allows downloading the Nokia C7 original themes with blue color for free?
Yes, Shahad,
There are a lot of sites which will give you themes, games, softwares, etc. for mobiles for free. Here is a list of those sites, which I personally like. Just specify your Nokia C7 model, and you will be able to find everything for it.
etc.
Hello Shahad,
There are a few websites I know, which you might want to check.
Nokia store (Ovi) (Link: http://ovi.sigma.apps.bemobi.com/en_us/?utm_source=store.ovi.com) can be used. Set the device to Nokia C7, Select the Symbian version you use, Select the tab 'Personalization' at the right side of the page, chose themes and you can easily pick your theme.
http://www.onsmartphone.info/ is another web site which can be helpful. This URL will take you straight to the Nokia C7 themes page. There are about 900+ attractive themes here. (Link: http://www.onsmartphone.info/themes-for-nokia-c7-00/)
I suggest you take a look at these sites as well.
mobile9.com, emobilez.com, symbianthemes
Specially zedge.net website which have really attractive themes (blue color themes) I spotted on my first visit. I've eased up your work, here are the links to the search results.
http://gallery.mobile9.com/c/nokia-c7-00-themes_3230/1/original_15/
There are so many web sites from which we can get themes and other things for Nokia C7 mobile in original blue color. One of these is: http://www.onsmartphone.info/
There are 935 different themes only for Nokia C7 mobile which are categories under different heads. You can select and download or you can save in file to the system then to your mobile. There are so many other sites from which we can get it.
