Can I download youtube videos?
Hi Friends,
I have selected a video list on YouTube. But I am afraid there is no download option.
Can I down them alternately?
Hi Friends,
Hey Emmon Cabrera!
Yes! You can download YouTube videos. It’s very easy. There are many software on the internet that can help you in downloading the YouTube videos.
If you are using Mozilla Firefox for browsing then you can use YouTube plugins for your Mozilla Firefox. When you will install the plugins, you will see a download option on every video.
Despite of all this, you can use Internet Download Manager. When you will install it, an option for Download with IDM will automatically appear on every video. You can click on it and download your video.
Tunacao Caaron
Hi There,
I think you need help regarding the downloading of YouTube videos.Â
There is no genuine method of doing it since Google says YouTube is for watching videos online not on personnel hard drives.
There are many ways to download YouTube videos.Â
I suggest downloading by using the YouTube Downloader.Â
YouTube Downloader is very good after their new update, Now the complete look is changed and its easy to use with their new UI (User interface), Very easy to download, Convert and store the videos or even watch it there itself. You can pause the download also.
The URL to download the YouTube Downloader is: –Â
Lesten Pasio,
Thank you for the download link of YouTube Downloader. I can now download videos in YouTube easily. You just need to put the link in the link column of YouTube Downloader.
YouTube Downloader is very awesome, it doesn't only download but can also convert videos.
At first download AVC software from the link given below.
http://www.any-video-converter.com/products/for_video_free/
Install the AVC to your computer. Then open the AVC and click Add URLs then copy and paste the YouTube video URL you want to download to drop down box then click start download button. After download you convert it to your desire video format.
Before you click convert you can set output folder from file > set output folder. It's fully freeware and great tools for downloading video from YouTube and converts any format even you can convert several video/audio format. I am using it about 3 years. See the screenshot for better understanding.
Yes, you can download YouTube video easily. A plenty of software is available on the net that enable you to download YouTube videos.
Hello dear,
It is very easy to download videos from YouTube. You have to use a YouTube Downloader for this. There is a lot of software available for YouTube downloading, but I suggest you use the Internet Download Manager. When you play a video, it will make a button like this.
Just click on it and the video will download.
This is a link to download the Internet Download Manager.
http://www.internetdownloadmanager.com/download.html
