juross jude
Posted on - 11/04/2011
Hi!
I learned to work with Adobe Photoshop 7.0 by myself, using tutorials and lessons from the internet.
Can anyone tell me if it’s possible for someone to earn enough for a living from only working in Photoshop, and if not, what is the best program anyone should learn?
Can I earn enough for a living as a Photoshop designer?
Adobe Photoshop 7.0 is a power tool for designing. This software is widely used by software designer and graphic artist anywhere you are.
To be familiar with this footwear and know how to use is an advantage to anyone anywhere you are. You will earn good living of this because web, images and graphic designer nowadays is in need by many.
If you are good at it, then for sure you will find good fortune on this plus if you add your determination to learn new things such as other Photoshop tools, you will find yourself as future graphic artists.
Graphic artists can earn good money by showing there talent as an artists using this Adobe Photoshop tools. You can set-up your own shop that master web designing, printing and other images enhancement. You can apply an online job as freelancer or a web designer.
There are websites that is in needed of this talent. If you know this software on how to operate, then I would suggest to master this tool. It'll be an advantage for you find yourself heading in this direction.
lee hung
75 points
Hallo Juross,
For sure you can earn a living by just using adobe Photoshop 7.0. With the powerful capabilities that it has for creating 3D images and very good images that you can use in a website, you can be able to design quality images and sell them to people in form of logos, banners and other images that people might need.
You can use adobe Photoshop 7.0 to create animated images which are suitable for websites that may not be able to use shockwave images, edit pictures from camcorders and create very quality templates that can be used by people developing websites.
This is just but a few things you can do with Photoshop; there is a whole range of other things you can still do with it.
_
Regards
Lee Hung
