Good day,
I have Premiere Pro CS4  and have encoded several hours worth of f4v splitter files , now I want to edit f4v files, is there any way that I can edit 4fv files? If there are other 3rd party solution then tell me about it.
Thanks
Can i edit f4v splitter files?
Hello, Sharon D Mickelson
Hope you are fine. I think I can give you a solution. So don’t worry.
You should be happy to hear that I can give you a video result so that you can learn how to edit f4v step by step.
See the video result
Otherwise try it
Go to Capture section launching the program.
Now switch to the browser and
Click to play the FLV/F4V video.
You will find the FLV/F4V URL placed in the Downloader, while the video is playing.
Then select the URL and
Click the Download button to download.
You will find the downloaded FLV/F4V in History or Library after download.
Right click on file and
Now you will have selections to play, edit or convert the FLV/F4V.
Hope you will get your answer.
