effieclyde
10 points
Posted on - 05/25/2013
Hi fellow Techyv members. I have inserted a calendar template with text notes capability on my website. Is it possible to edit text calendar template notepad? I'm on a Windows 8 OS. Any help would be much appreciated. Thanks in advance guys.
Can I edit text calendar template notepad?
Hi Effie,
If you are working on a website based on HTML you can try this step; however this step can be used when editing information on your calendar through Rich text format. Go to Site actions > Site Settings > Site Columns > Create new site column look for Event Description and then on your Calendar navigate to the list settings. And then try to make the necessary changes on your calendar entries.
