Can I enlarge Chrome icon size?
I'm using Google Chrome version 10 on Windows Vista 64 bit. Is there any way I can enlarge Chrome icon size from 48×48 pixels to 256×256 pixels? The icon is too small.
You have two choice how to change the icon size on Windows Vista. One of it is to click on an empty space on desktop and go to Personalize and then choose the Windows Color and Appearance. On the bottom on the open window you will see Open classic appearance properties. Click on it and choose Advanced. Here you have Item size and font, so you can change it as you want.
The other way you can do that when you are on desktop screen press CTRL key and while holding it scroll with mouse wheel up or down.
Williamson Mellisa
Notifications
