As the title says, I have about 20 PDF files which I want to export to XLS.
Someone told me I must convert them directly to XLS format.
So I come here to TechyV Support asking for some help.
If you can, please assist me to export PDF to XLS on Mac.
Provide me with solutions or software's that will help me do this in a easy way is possible.
Can I export PDF to XLS on Mac OS X
Try for free pdf to excel conversion https://www.pdftoexcelonline.com/
PDF can be created easily from file types like .doc files or .xls files. But it is kind of difficult to convert it the other way. However, this can be done in Excel or when using a free converter. To convert PDF to xls, you need to save the PDF file first as a text file. To do this, follow the steps below:
1. Launch PDF in Adobe Reader.
2. Click File and then Save as Text. Browse to where you want to save the folder and then click Save. This will save the PDF as a .txt file.
3. Launch Excel on your Mac PC and then click the Import button.
4. Choose file type that you wish to import and then click Import.
5. Go to the text file that you just saved and select it. Click Get Data to launch the Text Import Wizard.
6. Follow the instructions on the wizard to format your data. Select the delimiter type of your data and the column format that you wish for your worksheet. Choose the necessary options in every three pages of the wizard, just click Next to continue.
7. Click Finish when done.
8. Click Existing Sheet to get the data from the current blank document and click OK.
9. Save your worksheet.
10. Go to a website with Online PDF to Excel Converter.
11. Browse to upload your PDF file.
12. Choose the file and open it.
13. Choose XLS as your output file type.
14. If prompted to enter your email address where the converted file would be sent, enter your email address.
