Can I Fix The 0xa00f4271 (0x80070001) On Windows 10?
I am unable to use the integrated webcam on my Windows 10 PC. I updated the drivers, but it did not help. The error that I am facing is 0xa00f4271 (0x80070001). Can I fix it?
You can try the following methods to fix the 0xa00f4271 (0x80070001) error in Windows 10.
Method 1
a. Search Troubleshooter in the Search box and open Troubleshooting settings.
b. Go to advanced troubleshooting options if you do not find the list of troubleshooters.
c. Click on Windows Store Apps, and Run the troubleshooter.
d. Complete the process, and the error will be gone.
Method 2
a. Search for Windows Update in the search box, and open it.
b. Click on Check for updates.
c. Complete the process, and check if the error is gone.
