Can I Fix The 80090030 Error Code Manually?
When I enter the password in Outlook 2016 with Office 365 account, it throws the 80090030 error. Can I fix the error manually?
You can try to fix the 80090030 error manually. If the error persists, you need to contact a specialist.
Method 1
a. Open Windows Defender (Search in the Windows start box).
b. Go to the Windows Defender Security Center.
c. Go to Device security.
d. Open Security processor details.
e. Click on Security processor troubleshooting.
f. Clear TPM.
g. Restart your device.
h. The error should be gone.
Method 2
a. Press Windows + R on your keyboard.
b. Type tpm.msc and press enter.
c. Click on Action.
d. Turn TPM off.
e. Restart your device.
Method 3
a. Open TPM, as mentioned in the previous method.
b. In the right pane of your window, click on Prepare your TPM.
c. Complete the process.
d. Restart your device.
