I was wondering, if I would be able to get bluetooth for HP Windows 7 Starter edition. I saw that a friend of mine has it on his laptop, and it would really ease up my work. Transfering files from laptop or smartphone to the computer would be a lot easier, and I do transfer a lot of files per day. Do you guys know if I am able to get such a software? Does my computer need something or I can just set it up? Thanks for all your help.
Can I get bluetooth for HP windows 7 starter edition
Hi John,
Windows 7 starter edition is supported with Bluetooth. You may have to install or upgrade your Bluetooth drivers from the manufacturer's website.Also make sure that the Bluetooth on your laptop is switched on. The integrated module with Bluetooth wireless technology provides wireless connectivity to other devices from the integrated module of the supported laptops. If you are still facing problems with your Bluetooth even after switching on your device then try to install this.
Software-for-integrated-module-with-Bluetooth-wireless-for-Microsoft windows-7. This will work with all Windows 7 Flavors 32-bit and 64-bit.
