Harold Rudy
50 points
Posted on - 11/15/2012
I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
Yes, you can add more power cords to your power supply, and it can take a lot of your power load if they are from a good company, but you can't do it by yourself. You will need to take it to a mechanic. One thing you can do is check your existing wires and connect the new wire yourself. Thanks.
Hi Harold,
If you mean adding a power cable to your computer’s power supply, then what you need is a power supply cable splitter.
See the image below:
This type of cable is available from your local computer store. It’s called a MOLEX 4 Pin power supply splitter cable.
As a precaution though, I would suggest you confirm if your power supply can accommodate any additional load. What kind of component are you planning to add to your computer which requires you to add a power cable? Overloading your computer’s power supply has adverse effects. It may cause your computer to crash or it may render the components unusable.
I suggest installing a power supply calculator such as Extreme Power supply calculator to verify how much power you need and to find out if your current power supply can handle an additional device.
You may learn more about Extreme power supply calculator from the link below:
https://outervision.com/power-supply-calculator
