I need a good power supply to use with my Core i3 MSI Z77A-G43 socket, i7 ATX Motherboard W/Z77, USB 3.0 and a DVI HDMI. The problem is that i do not know the kind of power supply to buy for this. Anybody with an idea or an explanation on the kind of power supply that i should get? I will be glad. Thanks
Can I get a good budget power supply?
There are plenty of power supply available in the market now a days. The Core i3 has lower power consumption, so even 350W power supply is enough for that configuration. However I would suggest you to choose at least 450W which can accommodate future upgrades in your system. There are brand name systems like HP, Dell, Acer etc.
Also, you can use online power supply calculator to calculate power consumption of your system.
