Can I get some good linear wave foam viewer?
This is a bit way off, but I know that there are a number of musicians out there who have inhabited the RW World. I wanted to ask anyone who has heard of Garage band can to give me some keywords. I am a pianist by profession, and I want to be a professional pianist. I’ve got this piano it has two octave, touch sensitive, a weighted keyboard, can I get some good linear wave foam viewer that I can use?
Answered By 0 points N/A #153267
This is not the right thing to do; you must either get a class of this or get a tutor to teach you how to do this.
There are few other software’s available too that gives you a visual form of the waves produced during the playback and that you can edit them afterwards so that they can sound better.
Sometimes it is way too much difficult to track down the waves since it is the only thing that the musician has to be taken care off and if even this has to be done via software then what is the use of the musician, you just create a symphony over the software by changing the frequencies.
